drvox Posted April 17, 2007 Share Posted April 17, 2007 Hi all, I'm having some trouble here with my scene. I have an HDRI in environment slot in vray settings. Also have a bitmap in the render background menu. While I only had the direct light it was everything ok, and the bitmap was appearing correectly. Since I got a vray plan light inf fornt of each window I can't see the background bitmap (sky) as you can see in the attached file. I have the vray lights set as invisible, since the garden is visible. Any help? King Regards. Link to comment Share on other sites More sharing options...
Woody Posted April 17, 2007 Share Posted April 17, 2007 Has the glass got a thickness? That can cause a problem. Link to comment Share on other sites More sharing options...
asarria Posted April 17, 2007 Share Posted April 17, 2007 Try using a dome vray light instead of a plan light. Are you using the Simian Glass material add-on? Another suggestion is that you may want to check if the exterior light is not being obstructed by any environment objects like a dome. Good luck. Link to comment Share on other sites More sharing options...
