ChooChoo Posted April 18, 2007 Share Posted April 18, 2007 I think I already know the answer to this, but just maybe... I use Revit for my modeling and it has parametric abilities built in for windows, doors, etc. I can have, for example, the entire Anderson Windows size collection in one file. If I need to have a different size, I don't need to remodel, just change the width and height parameters. So I was wondering if this can be accomplished in Max. I know there is a parametric window and door in Max, but it's the style that I would like to change. Meaning grids, no drids, half grids, profiles, etc and so on. Link to comment Share on other sites More sharing options...
ChooChoo Posted April 20, 2007 Author Share Posted April 20, 2007 I guess that would be no? Link to comment Share on other sites More sharing options...
only3d Posted April 20, 2007 Share Posted April 20, 2007 im not sure i got what u meant, but if parametric windows u r looking for then yes there are most definitly there (not a big fan but they exist) theyre called AEC objects and u can change all the parameters u asked about, but if you want to create a "style" that u can save and use again & again then the answer is no.. (well at least to my knowledge). from my experience u can create quite nice objects but not nearly as elaborate or user-freindly as 'archicad' for example. (no door knobs for instance..! ) thats it my freind, hope this helps Link to comment Share on other sites More sharing options...
Koper Posted April 20, 2007 Share Posted April 20, 2007 the AEC objects are gr8, if you know how to use them, and after you created an object you can just save selected' and merge it into an objects file so that you don't have to re-create every time, then the next time merge your objects file into you scene and re-use them. also another cool thing is that you get and AEC material for any particular object, this material is only a multisub-object material so you don't need to assign new IDs Link to comment Share on other sites More sharing options...
Vince Paske Posted April 20, 2007 Share Posted April 20, 2007 Max's aec objects are not parametric in the sense that if you change the size of a door or window, the wall it is in will adjust to acomodate the new size like in Revit. There is no association/intelligence between geometry and data like schedules you find in Revit. Link to comment Share on other sites More sharing options...
ChooChoo Posted April 21, 2007 Author Share Posted April 21, 2007 That's kind of what I thought it would be. That's too bad. Thanks for the replies everyone. Link to comment Share on other sites More sharing options...
Quique Posted April 21, 2007 Share Posted April 21, 2007 My experience has been that when an AEC window/door is linked to an AEC wall, an automatic 'subtract' Boolean operation occurs. So if you do change the size of the window/door, the opening in the wall will adjust. Unfortunately, you get funny effects when simply translating (moving) a linked window/door. Link to comment Share on other sites More sharing options...
