ZFact Posted April 18, 2007 Share Posted April 18, 2007 Hi All; Decided to take the plunge and start learning max. I have a few simple questions:- 1. What is the best modelling method? Boolean, Extrude Spline or box & Slice 2. When you import the line work from Autocad is there any setting I should be aware of.. i already figured out the scale thing. Should I group the line work or send to back...? or anything else i should be aware of. 3. Can you subtract or add one extrude to another? 4. Can you give a spline a thickness, just so that it stands out from the imported linework? 5. When drawing a spline how can you pan around the linework with your spline still open? Thanks, thats all for now. Link to comment Share on other sites More sharing options...
Trevor Tizard Posted April 18, 2007 Share Posted April 18, 2007 I import elevations from autocad, then freeze them and trace over with 2.5d snap with a spline and convert closed areas to editable polys. There are lots of ways of modeling, this is just one. A bit vague I know, but should get you started. PS move your autocad drawing to 0,0 before importing. Link to comment Share on other sites More sharing options...
ZFact Posted April 18, 2007 Author Share Posted April 18, 2007 Thanks Trevor; When i freeze the imported linework.. i cant get the splines to snapped to it... snapps fine when not frozen Link to comment Share on other sites More sharing options...
ZFact Posted April 18, 2007 Author Share Posted April 18, 2007 its ok Trevor; Figured out the problem... cheers Link to comment Share on other sites More sharing options...
Trevor Tizard Posted April 18, 2007 Share Posted April 18, 2007 make sure you are using 2.5d snap - should be fine Link to comment Share on other sites More sharing options...
ZFact Posted April 18, 2007 Author Share Posted April 18, 2007 one last thing trevor what do you mean by closed areas and can you subtract and add editable polys to one another? thanks again Link to comment Share on other sites More sharing options...
Trevor Tizard Posted April 18, 2007 Share Posted April 18, 2007 OK closed as in closing a ployline. So very briefly, try this: Draw a rectangle, deselect "start new object" and draw another smaller rectangle inside the first. Right click and convert to editable poly. You should now have a plane with a window in it. This is how I model buildings. Link to comment Share on other sites More sharing options...
JamesTaylor Posted April 18, 2007 Share Posted April 18, 2007 Check out ted boardmans video tuts about modelling a house in max... it'll give you a very good intro the methods used, definately worth the time if you want to learn max. infact just start from the beginning and work thro and you'll be fine Link to comment Share on other sites More sharing options...
