Josh1587140445 Posted March 1, 2004 Share Posted March 1, 2004 Just looking for some C&C's on the lighting and any thing else you guys might see. I am using VrayFree GI with a Key and Fill light. One thing I am having trouble with is the grid-lines in the precast concrete in the rear protion of the building. They don't stand out as much as I hoped they would. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted March 1, 2004 Share Posted March 1, 2004 Hum...maybe this is happening cos you have only a fill light, not a shadow casting direct light. This kind of light makes details stand out more a bit, for it gives more contrast between lit areas and dark areas. Try that (and then, after playing with light, you might want to try some displacement grass). [] Rick Link to comment Share on other sites More sharing options...
Josh1587140445 Posted March 1, 2004 Author Share Posted March 1, 2004 Unfortunatly you can not do displacement grass with VRayFree. Unless there is a way in Viz. Other wise I was going to do a Scatter technique. It will increase rendering time. But it will look much better than the flat image currently there. [ March 01, 2004, 01:46 PM: Message edited by: Josh ] Link to comment Share on other sites More sharing options...
Josh1587140445 Posted March 8, 2004 Author Share Posted March 8, 2004 Here is an update on the rendering. A few more things that I want to get worked out. Link to comment Share on other sites More sharing options...
Chad Warner Posted March 8, 2004 Share Posted March 8, 2004 Overall looks pretty good. I think you need to work on the grass a little bit, try to get rid of the tiling. Also, the image looks a little bit gloomy, maybe crank up the environment lighting a bit. -Chad Link to comment Share on other sites More sharing options...
