midoo_egy Posted April 18, 2007 Share Posted April 18, 2007 hi all,i use autoCAD for modling ,3dmax 7 ,vray......all your C&C are wellcome. Link to comment Share on other sites More sharing options...
alfienoakes Posted April 18, 2007 Share Posted April 18, 2007 The modeling looks fine, its not the most inspiring building, but I am sure this isn't an architectural crit..! The shadowing is wrong.. It is way to soft for direct sunlight.. and it looks sort of "inky".. its way to black. You should be able to see some detail below those eaves etc.. The grass texture needs some work on it, its a standard texture you have used there, and hence tiles. Maybe some displaced grass for that size area would be good. Needs some more detail to the image as well.. maybe some foliage, a background to set it somewhere.. that sort of thing. The window reflections look a little to harsh, would be a bit darker in reality. Could generally just do with a bit more detail.. bring it to life a bit. Link to comment Share on other sites More sharing options...
