shikodesign2000 Posted April 19, 2007 Share Posted April 19, 2007 Hi there, How can I control shadows in vray animations, especially in exterior animations, I use for lightning a direct light, and vray shadows, I calculated the irradiance map, then light cache, and used (from file option) for both, then reder the entire sequence. My problem, is that the shadows is so light, and I want to make them darker, I tried shadows paramter in direct light, but no way. What's the solution please.. Link to comment Share on other sites More sharing options...
hussein Posted April 19, 2007 Share Posted April 19, 2007 are you using vray materials or std. & if std material may be you need to make the ambient more darker ...... from file option this mean that you took several shot for IR calculation is it right? hussein cgmine.com Link to comment Share on other sites More sharing options...
shikodesign2000 Posted April 19, 2007 Author Share Posted April 19, 2007 i'm using vray materials. Link to comment Share on other sites More sharing options...
shikodesign2000 Posted April 19, 2007 Author Share Posted April 19, 2007 i'm using vray materials, and yes i took several shots from ir calculations. Link to comment Share on other sites More sharing options...
kippu Posted April 20, 2007 Share Posted April 20, 2007 decrease the secondary bounce/ environment value Link to comment Share on other sites More sharing options...
shikodesign2000 Posted April 20, 2007 Author Share Posted April 20, 2007 can you please explain in more details.. Link to comment Share on other sites More sharing options...
The_architect06 Posted April 20, 2007 Share Posted April 20, 2007 decrease the gi environment (skylight) & you will have harder shadows also try to decrease the secondary bounces from your light cache Link to comment Share on other sites More sharing options...
shikodesign2000 Posted April 20, 2007 Author Share Posted April 20, 2007 yes ofcourse, i did it, thanks guys very much. Link to comment Share on other sites More sharing options...
