millhouse Posted April 21, 2007 Share Posted April 21, 2007 I am having two problems when rendering in V-Ray, I'm not sure if they are related. First I am getting noise/artifacts in a V-Ray material Glass, I have attached the image below. I am also getting warnings of overbirght or invalid colors, my lighting on the interior is not overblown but I am getting these errors on every peice of geometry in the scene. This is also the first time I am use V-Ray proxies (thanks to EverMotion's tutorials) I am on deadline so I am very desperate here. Thanks Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted April 21, 2007 Share Posted April 21, 2007 In order: 1- check you refraction subdivisions and refraction glossiness. They seem low. 2- check your white materials. They should not be 255,255,255. Try something like a very light gray, instead. Link to comment Share on other sites More sharing options...
millhouse Posted April 23, 2007 Author Share Posted April 23, 2007 Rick, Thanks for the feedback. As it turns out the problem is with the V-Ray proxies, for some reason when I save and close and then re-open the V-Ray proxies stop loading. I have to then Merge all of the geometry and lights into a new max file, which seamed to fix the problem. Has anyone else had this problem? Link to comment Share on other sites More sharing options...
