hayder3d Posted April 24, 2007 Share Posted April 24, 2007 Hi, this is first work using vray (camera,sun,plane,proxy) I'm waiting your notes to improve it especially that's some areas color changed, I can't understand why so I need your help Link to comment Share on other sites More sharing options...
mahorela Posted April 24, 2007 Share Posted April 24, 2007 I did some experimenting with it not so long ago. http://www.cgarchitect.com/vb/22770-vray-sun-sky-test.html hope it helps. Link to comment Share on other sites More sharing options...
hayder3d Posted April 24, 2007 Author Share Posted April 24, 2007 mahorela, thanks i read it know what do you think about work it is good or not Link to comment Share on other sites More sharing options...
rpompeu Posted April 24, 2007 Share Posted April 24, 2007 Hayder, I think lighting is good, just think that you should work work on the trees and palm textures. Link to comment Share on other sites More sharing options...
mahorela Posted April 24, 2007 Share Posted April 24, 2007 I think it's perhaps too evenly lit......needs to be some more contrast between light and shadow. Also I think your turbidity is too high and is coming across as too warm. It would help if you raised the height of the sun a bit, seems as though your palm tree shadow is falling horizontally. Link to comment Share on other sites More sharing options...
stormchaser Posted April 24, 2007 Share Posted April 24, 2007 1-the position of sun suggest its late evening/sunrise but the intensity of light suggests its around afternoon, so as bob suggested youll have to take sun higher, 2- ground needs more work, trees , better grass texture etc. Link to comment Share on other sites More sharing options...
hayder3d Posted April 24, 2007 Author Share Posted April 24, 2007 hi guys , thanks a lot to your notes i will take it especialy height of sun and ground but no one give me the reason of unexpected spots color like in the forth pict. and how can solve this problem Link to comment Share on other sites More sharing options...
liang Posted April 26, 2007 Share Posted April 26, 2007 Link to comment Share on other sites More sharing options...
