BrianKitts Posted April 24, 2007 Share Posted April 24, 2007 I threw together an outline on how to use the free panotools in conjunction with the free panocube scripts to generate QTVRs. Thought I would post it here for others to try out. I originally picked this workflow up off of suggestions Jeff made on the forums a couple of years ago, but since I had unistalled the programs and lost them I thought I'd document a guide to make it easier. These instructions are specific to PC, the readme files that come with the programs explain the mac version as well. step 5 is specific to vray, but you can use the panotools to generate the image as well from any render at which this process would apply to all software. SETUP STEPS ------------------------------------------------------------------------------- 1. Extract files to HD for panocube http://www.panoshow.com/panocube/PC00292.zip 2. Extract files to HD for panotools http://www.all-in-one.ee/~dersch/PanoTools.zip 3. Copy pano12.dll from panoTools folder, to \\windows\system folder 4. Drag PTStitcher.exe from panoTools\Helpers onto Panocube.exe 5. Render image from vray using spherical camera, over-ride FOV to 360, and image size 2x wide : 1x height 6. Drag rendered image file onto panocube.exe The source image must reside in the same folder with panocube.exe when you drop it onto the .exe 7. You can customize the output file by editing script.txt in the panocube folder. 8. The output file will show up when completed in your panocube folder along with an html file which loads the QTVR. (the html option can be disabled in the script.txt) ------------------------------------------------------------------------------- extra note: Panolink available for $30 to create active hyperlinks between QTVRs http://www.panoshow.com/panolink/index.htm ..enjoy! Link to comment Share on other sites More sharing options...
batteryoperatedlettuce Posted April 25, 2007 Share Posted April 25, 2007 been itching to try this - thanks mate. Link to comment Share on other sites More sharing options...
Ray1618 Posted March 25, 2008 Share Posted March 25, 2008 Hi hello I tried to use the pano cube program from your program and followed your steps till dragging the image then it seems to work. But it doesn't, I don't get any output and no errors. Is this also suppost to work for xp? Link to comment Share on other sites More sharing options...
BrianKitts Posted March 25, 2008 Author Share Posted March 25, 2008 Is this also suppost to work for xp? Yes I've used it successfully XP, pro and mediaCenter Link to comment Share on other sites More sharing options...
Ray1618 Posted March 26, 2008 Share Posted March 26, 2008 Yes I've used it successfully XP, pro and mediaCenter Thank you. I readed the readme now & found out that it's wrong to put the program on the desktop cuz of the path used spaces then Link to comment Share on other sites More sharing options...
SandmanNinja Posted May 24, 2008 Share Posted May 24, 2008 I know this is an old post, but I'd thought I'd give this a try. I'm using XP64, have a spherical JPG that is 5000x2500 pixels. It scans it and makes a single MOV file, but nothing I have opens it. QuickTime just sits there, thinking about it. I have all the files in my c:\PanoCube folder (no spaces in path or filename). Any ideas? Link to comment Share on other sites More sharing options...
SandmanNinja Posted June 3, 2008 Share Posted June 3, 2008 Well, I got it to work fine on my 32-bit OS So... there's that. Thanks for these tips! Link to comment Share on other sites More sharing options...
BrianKitts Posted September 9, 2008 Author Share Posted September 9, 2008 Well, I got it to work fine on my 32-bit OS Just did a bit of testing as I'm cranking out a few of these again, and you are correct. You can create and view on a 32bit machine without any problem. I can run the script on my 64bit machine to create the .mov file but you can not view it on a 64bit machine. (a file created on 64bit views fine on 32bit machine) So it looks like its a quicktime limitation for 64bit, I'll be doing some more looking in to this one as we are upgrading all of the machines in the company to 64bit. (three cheers for digging up old threads) Link to comment Share on other sites More sharing options...
SandmanNinja Posted September 10, 2008 Share Posted September 10, 2008 I use this - someone here put me on to it - and it works great! I use it with Firefox 2 and WinXP64 Check out DevalVR: http://www.devalvr.com/paginas/productos/qtvr.html QTVR features supported These are the QTVR features supported by the last version of the viewer: - Preview images - Cylindrical panorama movies Cylindrical panorama example: http://www.devalvr.com/paginas/soporte/compass.html - Object movies Object movie example: http://www.devalvr.com/panos/objectmov.html - Cubic panorama movies Cubic panorama example: http://www.devalvr.com/paginas/galeria/dining_room.html - Tiled cubic panorama movies Tiled cubic panorama example: http://www.devalvr.com/paginas/soporte/joystick.html Link to comment Share on other sites More sharing options...
bleeding_me Posted March 27, 2010 Share Posted March 27, 2010 5. Render image from vray using spherical camera, over-ride FOV to 360, and image size 2x wide : 1x height Hello Brian, i was gonna try this "tutorial", but where is the spherical camera in vray ? because in the vray physical cams i only see Quadratic and Cubic distortion type. thanx bleeding_me Link to comment Share on other sites More sharing options...
kippu Posted March 28, 2010 Share Posted March 28, 2010 it is not in the vray physical cam ... it is the vray : camera rollout in the render setup dialogue, when the tutorial came out there was no vray physical cam Link to comment Share on other sites More sharing options...
