drvox Posted April 25, 2007 Share Posted April 25, 2007 Hi all, It's quite difficult to describe what's happening. :confused: My glass allows to see objects behind it, but the background becomes all black. Tryed with background image and with a pure white background but got it always completly black. There are some pics and the test file in the attachments. Any help is welcome. Don't know what to do at all:( King Regards Link to comment Share on other sites More sharing options...
gfa2 Posted April 26, 2007 Share Posted April 26, 2007 My glass allows to see objects behind it, but the background becomes all black. You have your enviroment reflect/refract set to a black color and 100% reflection and refraction on your material so you are getting glass that you can see through but your PortoView enviroment map is being over-ridden by black. Turn that reflection/refraction override off and you should be ok. Link to comment Share on other sites More sharing options...
allwhiz Posted April 26, 2007 Share Posted April 26, 2007 Hi all, It's quite difficult to describe what's happening. :confused: My glass allows to see objects behind it, but the background becomes all black. Tryed with background image and with a pure white background but got it always completly black. There are some pics and the test file in the attachments. Any help is welcome. Don't know what to do at all:( King Regards can you help me setting max environment on dark environment as i have seen your display image? THANKS Link to comment Share on other sites More sharing options...
drvox Posted April 26, 2007 Author Share Posted April 26, 2007 Thanks a lot! I'll try it as soon as I arrive home. About the black layout, you have to go to Customize Load Scheme and choose the black one. If you still have any doubt tell me and at home I might give you more detailled information. I haven't max in this pc. King Regards Link to comment Share on other sites More sharing options...
