Macpod Posted April 26, 2007 Share Posted April 26, 2007 hi guys. I want this scene to have a more diffused look and with some flaring if thats at all possible. Also, is it possible to actually 'show' the sun in a rendering? as, in how do i create a big bright sunlight sphere? cheers Yihang Link to comment Share on other sites More sharing options...
Wayne Harney Posted April 26, 2007 Share Posted April 26, 2007 You can use the lense effect in max under "render effects". I think it only works with scanline although I've rendered vray animations, set the animation as environment map in a new scene, create a light and render the effect on top of the original animation. example Link to comment Share on other sites More sharing options...
Macer Posted April 26, 2007 Share Posted April 26, 2007 Using MR 3.5 Daylight system will show sun (if its in the correct time/angle etc) Not to sure about flaring though.... Link to comment Share on other sites More sharing options...
Horhe Posted April 26, 2007 Share Posted April 26, 2007 You can use the "Video post" under max to add the lens flare effect. There youve got loads of different settings to crank up Link to comment Share on other sites More sharing options...
Macpod Posted April 27, 2007 Author Share Posted April 27, 2007 thanks guys, will give those suggestions a shot. Link to comment Share on other sites More sharing options...
erbalaji Posted April 28, 2007 Share Posted April 28, 2007 thanks for you news. it's new for me.. Link to comment Share on other sites More sharing options...
Macpod Posted April 28, 2007 Author Share Posted April 28, 2007 Just added a simple glow effect under lens effect. Its not fancy but fine for what im tyring to show. Havent tried the video post things. I noticed there were only 5 lens effect in stock 3d max 8, is this right? Link to comment Share on other sites More sharing options...
