visualmusic.4 Posted April 27, 2007 Share Posted April 27, 2007 I'm having a very strange situation with a max file that I've been given from another client. I've added lighting (it's an exterior shot) but cannot get ANY shadows casted whatsoever. I've tried every lighting solution I can think of and still no luck. From standard lights, to photometric and radiosity solutions still no luck. Cast shadows is checked. I even applied a general white phong material to everything in the scene and still no dice - so it can't be the materials. What can I be missing? Any help would be appreciated. I'm totally perplexed... Thanks everyone! Link to comment Share on other sites More sharing options...
jason_s Posted April 27, 2007 Share Posted April 27, 2007 check the scale of your model.......if it is very small it happens to not cast shadows. Link to comment Share on other sites More sharing options...
visualmusic.4 Posted April 27, 2007 Author Share Posted April 27, 2007 Thanks Jason. The land mass is about 2,800'x4,000' so it's pretty big. Man this is crazy. All I want is a light to cast simple shadows! Weird. Link to comment Share on other sites More sharing options...
jason_s Posted April 27, 2007 Share Posted April 27, 2007 try scaling up the model a lot and see if you get shadows......that was once the answer to a similar problem i had........i had prepared the model in cad brought it over, lighted it and no shadows...and it was the scale of the thing. Link to comment Share on other sites More sharing options...
ajvbochove Posted April 27, 2007 Share Posted April 27, 2007 I think you already checked, but maybe: Render Scene (F10) Shadows & Displacement Enable must be checked. or Maybe your geometrie properties are changed to not to cast shadows Link to comment Share on other sites More sharing options...
visualmusic.4 Posted April 27, 2007 Author Share Posted April 27, 2007 Yes! That's it. This wasn't checked. Looks like the client had changed a bunch of settings in the render scene window. I went down to the bottom and changed back to the default presets and started fresh. Now it's all going smoothly. Thanks for your help! Link to comment Share on other sites More sharing options...
