al_farooq Posted April 27, 2007 Share Posted April 27, 2007 hi all, may u help me about tiling that how i can use tiles on a kitchen floor and on walls and donnot forget to tell me about tile patterns too.because in reall life we can use tiles in so many styles. for example in more cases normally we use two tiles rows all around the walls room then use a border and after that another design tile. pls help me about tiling in 3ds max and if u know any website tutorial about floor and walls tilling pls inform me Link to comment Share on other sites More sharing options...
kingdavid88 Posted May 21, 2007 Share Posted May 21, 2007 i don't have a clue about this either?.. in the same boat Link to comment Share on other sites More sharing options...
AFK_Matrix Posted May 21, 2007 Share Posted May 21, 2007 Well either use Photoshop or some paint software and make up the wall as a texture/material. Or split your wall up with material ids or detach the faces of an editable mesh. Link to comment Share on other sites More sharing options...
flooatz Posted June 8, 2007 Share Posted June 8, 2007 i thing u can tile it( tile effect) by adding tile effect in material lib. Link to comment Share on other sites More sharing options...
Andy Park Posted June 12, 2007 Share Posted June 12, 2007 I would use a multi material with different version of the tile material in each slot. By the sounds of your design you need 3 seperate tile type. bottom, border & top. assign the matrial to your desired faces. remember to add a uvmap to your faces (not the whole geometry) to allow you to size the 3 different tile textures correctly for walls of different sizes. Link to comment Share on other sites More sharing options...
