VraySphereFade images..
shikodesign2000
Hi,
Here's the problem of the plugin "VrayShereFade" which is used to render only the influenced object by this plugin, in the first image you can see the box which is influenced by the plugin, only the visible rendered part of the scene is this box and very small part of the box base, the plugin is working properly.
when i move the camera to the other side of the box, the plugin doesen't work, and all the scene is rendered!!
If anyone can tell me why??he'll introduce for me a very big favour.:(
To try this plugin, please go to:
Rendering menu, Environment, add atmosheric effect, then add "VraySherePhade", then pick the atmosheric spherical gizmo which you have to add it and surround the object which you want to render it only without the rest of the scene.
This's the link of the tutorial of "moving objects in vray animation", and you can find the plug in here.
http://www.spot3d.com/vray/help/150R1/tutorials_anim.htm
I hope to have any help in finding the reason of this problem.:confused:
