network rendering at 50 ft
ChooChoo
I am slowly coming up to speed on my rendering. I have 3 computers which I can farm together. Mine, my wife's, and my daughters. I built all of these and they all can do some pretty good processing. I figured my rendering, prolly just like everyone else here, is the drag in production. I am already hooked up to my wife's which is right beside mine, with firewire and I have no complaints about the speed.
My daughter's is the question. It's 50 ft away as far as the cable routing will go. I know there is length limitations, but I was wondering if I could get some clarity. I think this place, some people would have something like this setup already. I can firewire, or crossover cable to my ethernet card. Firewire seems to have the limitation, but right on the border, like 15 m's which I might be able to make that stretch. That would be 400 mbs if I read correctly.
And gigabit, which could get me 1000 and maybe longer distance. Is that correct?
Understand, I don't want the bandwidth just for giggles. I have a master plan! Eventually, hopefully, I can configure my house up so I can have toys everywhere, but I know that gets me into different hardware setups like gigabit routers and such. This is just comp to comp, no router.
Any suggestions? Firewire OK with the right cable (and which) or crossover cat5e?
hi
I'm not an expert but, last quarter I tried to setup a micro network rendering farm with:
1 bipro xeon 2.8 2 gig ram
1 bipro xeon 2.8 1 gig ram
1 bipro opteron270 2 gig ram
1 qx6700 2 gig ram ( my new beast)
Guess what?
I did not have such good results because the computers were too different in their speeds.
My quad does better alone than with his little friends !
The closest your computers are (type of cpu, ram)the better it is.
pierre:D
hi
actualy, the processor type is not relevant, if your network is well done. 50ft is just 15 meters, so if you have a correct switch ( -/+ 200 us dollars for 4-8 ports), every aded computer should bring you something. as little it is.
i've used cinema4d xl in network rendering, with those old colored iMacs (first generation) had 20 of them, and i can tell you their was pretty fast together, and this was 6 years ago :-) and i also did it with after-effects.
this is just a matter of networking them good.
good luck.
With a router, hub or switch you do not need a crossover cable. Use a crossover when going directly between 2 computers or hub-to-hub when the hubs don't have an uplink port. BTW, you don't need Cat6, you can use Cat5 but the recommendation is usually that you can choose 5e or 6.
That's what I was going to do is the comp to comp setup. I already have two connected and have other ports to spare. I'm pretty sure both comps that I want to hook up have gigabit cards. I figured I would go for the gigabit, but the firewire on my 2 existing computers was a snap.
I'm sure I have to do some in-depth reading on how to set it up for the gigabit if I remember correctly from hooking up my original 2.
400 compared to 1000. I can definitely use that bandwidth up no problem. 100 is way too slow.
  Ernest Burden said:
Will a gigabit router work at that speed if ANY machine connected to it is slower? I think I read that recently, but I'm not sure.
As far as I know, it doesn't make a difference what speed is hooked up to it. Of course a gigabit router only makes a sense if you have other machines that are gigabit.
I have BB setup thru a VPN with Systems here, 10 more in an office 50 miles away and 6 more machines in an office in Europe that I can use. and I have machines in the remote and overseas office that render faster per frame then I do with any of the 10 local machines. It all is really based on how large the scenes are, and what you are tring to render. if you are using DR to render then the slower machines really do slow you down, but if your doing a 5,000 frame animation, then all the machines will help out.
I was just talking to a guy who does corporate networking while we watched our kids play soccer. He said that with regular ethernet cables (cat5 or cat6) you can go 1000 feet, but beyond 400' - 500' you start to get data loss and other problems. So if you're going farther than that use a router to keep the signal strong.
He said the new networking his company is putting in for customers is copper based and is cat7. And that the next step is possibly to use existing electrical supply systems to carry data. That's a pretty big installed network, the power grid.
We need a "Tim the Tool Man Taylor" kinda guy to do gorilla grunting sounds about new technology coming up or cool things people do with it.
My other post I did on the wiring kinda goes hand in hand with this thread a little. Can firewire not be used between computers without the router switching stuff? Maybe I'm too paranoid about stuff being too complicated to switch over. It's new territory for me.
I have a router, but only at the 100 speed which wouldn't harm the rendering stuff I guess.
I don't plan on going over 100' total anywhere in the house.
