sonofalion Posted April 30, 2007 Share Posted April 30, 2007 I hate Mondays! Especially when it is a holiday on Tuesday, and you got to go to work instead of having a 4-day chance to go on a trip or sth. Anyway, I was feeling lazy and things at the office are kind of slow for a change, so I was playing around with Photoshop. I started with a white background and then applied Filter>Render>Clouds. Then I applied Filter>Blur>Motion Blur and cranked the distance all the way to the right (999). After that I used the Hue/Saturation tool with Colorize on, to achieve a dark brown colour. Then Filter>Artistic>Paint Daubs. Optionally you can add a bit of Gaussian blur or adjust the Levels or Hue or even add some Grain for the final outcome. This is what I got. Resolution independent wood texture. http://allyoucanupload.webshots.com/v/2001923880534859111 I'm sure with a bit more time it can get better, but I'm too bored to try now. Also another good Photoshop tip is creating brushed metal using just noise and Motion Blur. Paris Link to comment Share on other sites More sharing options...
STRAT Posted April 30, 2007 Share Posted April 30, 2007 i'm viewing an almost black square Link to comment Share on other sites More sharing options...
sonofalion Posted April 30, 2007 Author Share Posted April 30, 2007 Maybe your monitor's a bit dark (or mine a bit bright). Anywayz, here's a brighter version. http://allyoucanupload.webshots.com/v/2001025615972929978 Just try it on your own and see if it works. Link to comment Share on other sites More sharing options...
STRAT Posted April 30, 2007 Share Posted April 30, 2007 still looks way too dark. and my monitor settings are 90-95% brightness and contrast as standard. anyway, i put it in photoshop and adjusted the curves and levels to view it properly. i can see where you're comming from, but i think you need to play more and get more photoshop experience first before you can pass this off as wood. it's texture is un-wood-like, it's very dark, it carpets, and isn't adaptable to level/lighting changes. and there are fabulous photoreal tiling wood textures already available if you need one. if you want to go down this route i suggest you keep playing. it's definately good practice, but not viable for proffessional use unfortunately. please keep posting your results though Link to comment Share on other sites More sharing options...
