ki_cz Posted May 2, 2007 Share Posted May 2, 2007 I'm having a lot of trouble making a wet rock ... it just ends up looking like a plastic rock, or a rock covered in "gel" rather than water ... here are some of my tests with a tonne of different settings/bumps. Can anybody maybe give me some pointers? Link to comment Share on other sites More sharing options...
ki_cz Posted May 2, 2007 Author Share Posted May 2, 2007 Also, please let me know which one of the above you think looks most realistic! Link to comment Share on other sites More sharing options...
chiquito Posted May 2, 2007 Share Posted May 2, 2007 try puting a map on the reflection on the Vray material, the "wet" should reflect much nicer than what you have know, I believe there is a dvd fron gnomon, an outside scene on a higway, or something like that. Also try adding a wet map to the stone, there is a cd fron total textures, aged materials, that has some good mapas to do wet marks.ç Good luck. Link to comment Share on other sites More sharing options...
classix Posted May 2, 2007 Share Posted May 2, 2007 There is a tutorial on Neil Blevins page: http://www.neilblevins.com/cg_education/wet_materials/wet_materials.htm It´s not maxwell specific but maybe helpful nevertheless. Marcus www.einherzfuerpixel.de 3D Rendering, Animation und Architektur-Visualisierung - Aachen Link to comment Share on other sites More sharing options...
Devin Johnston Posted May 2, 2007 Share Posted May 2, 2007 I'm confused are you using Maxwell or Vray? Link to comment Share on other sites More sharing options...
SandmanNinja Posted May 2, 2007 Share Posted May 2, 2007 The Exterior Lighting tutorial from Gnomon covers this. They put a slick, wet sheen on the road texture. I think we just used a gray-scale map in the white channel of the falloff map for the spec channel. Link to comment Share on other sites More sharing options...
gfa2 Posted May 2, 2007 Share Posted May 2, 2007 The nine examples in the first image look more like a polished stone rather than a wet one. Just guessing here, but maybe the reflection should be sharper....less blurry. Link to comment Share on other sites More sharing options...
ki_cz Posted May 3, 2007 Author Share Posted May 3, 2007 For the first 9 I actually took what I considered to be the best 2 out of the bottom group and fooled with some settings. I will try making the reflections sharper to see if it gives me a better result. Link to comment Share on other sites More sharing options...
BrianKitts Posted May 3, 2007 Share Posted May 3, 2007 really good comment was made the other day that would apply to wet stone as well..... Keylitho said: ....Chrome is only as good as what you are reflecting. ~Erik out of context I don't think you can judge a wet material, it all comes down to the reflection and you can't judge that in a white box. (regardless of rendering engine) Link to comment Share on other sites More sharing options...
ki_cz Posted May 4, 2007 Author Share Posted May 4, 2007 It's Maxwell, and I'm using an hdri map to generate reflections. Link to comment Share on other sites More sharing options...
dave davidson Posted May 6, 2007 Share Posted May 6, 2007 top ones are nice i agree with the comments that its the reflections , environment you also try using some alpha maps for different layers and add some coatings to them so some areas are coated and some aint. Link to comment Share on other sites More sharing options...
