mooney102 Posted May 2, 2007 Share Posted May 2, 2007 Hello, Is it possible to search a Max file for a bitmap that is being used by a material?? My Problem: A Hdr is somehow attached to a material, but I am not sure what material or object this is. The hdr file is local on my machine. I am sending out the job to other machines to render, and recieve error opening Hdr file. This file is not is not show in the Bitmap/Photometric paths utility, and I cant locate it. Any Suggetsions?? Link to comment Share on other sites More sharing options...
Tommy L Posted May 2, 2007 Share Posted May 2, 2007 You could look in the material browser. But if its not showing in the path editor utility......I dont think it'll show in the editor. If its an hdr, are you sure you havnt put it in the environment slot? If you know what the map is, you could just copy it onto the render nodes, or do you want rid of it altogether? Link to comment Share on other sites More sharing options...
mooney102 Posted May 3, 2007 Author Share Posted May 3, 2007 I found that if you go into the vray log on the computer that is crashing, search for the missing map, that will lead you to the material with the missing map. Link to comment Share on other sites More sharing options...
BrianKitts Posted May 3, 2007 Share Posted May 3, 2007 under the file menu -> use the asset tracker. Any missing maps will be grayed out. Link to comment Share on other sites More sharing options...
mooney102 Posted May 3, 2007 Author Share Posted May 3, 2007 Yea, but the problem was that the map was inside of a Multi sub object material. I could not find which material or object was holding that file, and the asset tracker does not show which material it is linked to. Link to comment Share on other sites More sharing options...
