lyca Posted May 2, 2007 Share Posted May 2, 2007 little stupid question, if we use mental ray shaders and vray shaders in max, and assign the vray as renderer, what do max do ? are both shaders, mr and vray treated as vray in rendering ? Link to comment Share on other sites More sharing options...
AJLynn Posted May 3, 2007 Share Posted May 3, 2007 No, a mental ray material, a shader that's written for mental ray only, or an Arch&Design(mi) material, will only work with mental ray (and a VrayMaterial will only work with Vray). The only exception I've seen is that the new version of finalRender can use Arch&Design(mi) materials. Link to comment Share on other sites More sharing options...
Justin Hunt Posted May 3, 2007 Share Posted May 3, 2007 Thats interesting that MI shaders can be used by Finalrender, do you know if this is intentional or not? JHV Link to comment Share on other sites More sharing options...
AJLynn Posted May 3, 2007 Share Posted May 3, 2007 Yes it is. They also have a finalRender Arch&Design with the same functions as the mental ray one, so I guess they just put in a translator. Link to comment Share on other sites More sharing options...
Justin Hunt Posted May 3, 2007 Share Posted May 3, 2007 Very clever move, if there is a translator then I suppose other mi shaders can be used as well JHV Link to comment Share on other sites More sharing options...
AJLynn Posted May 3, 2007 Share Posted May 3, 2007 I don't think it actually works with mental ray shaders, it just reads off the settings from the Arch&Design material and interprets them like it's a finalRender Arch&Design material. So you could have a scene set up for mental ray and translate it a lot faster because most material settings don't need to be changed, or if you got a library of A&D materials you could use them. But you couldn't, for example, make a tricked-out old-school mental ray material and use that. Link to comment Share on other sites More sharing options...
Justin Hunt Posted May 3, 2007 Share Posted May 3, 2007 pitty, it would open up the Finalrender market share a bit if it could. JHV Link to comment Share on other sites More sharing options...
