shahrokh Posted May 6, 2007 Share Posted May 6, 2007 We are trying to compress PNG frames and dont know the best compression method to give us a small size animation with acceptable quality. Can anybody help please? thanks in advance www.batworkshop.com Link to comment Share on other sites More sharing options...
ikinman Posted May 7, 2007 Share Posted May 7, 2007 Are you trying to compress the frames or the movie made from the frames? There's a large difference...And the type of compression you would want to use will depend on the type of movie you make, not the type of file that the frames are. Link to comment Share on other sites More sharing options...
shahrokh Posted May 8, 2007 Author Share Posted May 8, 2007 we actually made an avi file out of our frames in 3dsMax ramplayer. then we tried to compress it using adobe premier pro. what is your suggestion in this case? thx Link to comment Share on other sites More sharing options...
Devin Johnston Posted May 8, 2007 Share Posted May 8, 2007 The best way to do animations is to render out the animation as individual frames in a format that premiere likes like TIFF's. Then you have the freedom to import them and edit them at will and compress them with the many different options in premiere. If you want descent quality with small file sizes you should use the windows media format. Link to comment Share on other sites More sharing options...
