first interior, two questions...
mare96
after a long period of modelling and rendering in formz, this is my first attempt to make a descent interior view.my passion for hyperrealistic renders found vray and i think that i'm in the right way.i know that i have to enhance my efforts, but i want your very first thought about this image.
i have 2 questions.
1)why the flowerpots shape is so deformed?
and
2)why the pavement of the yard is washed out?
tolis
i have 2 questions.
and
tolis
1) what kind of lens do you have? I'd guess it's a distortion because of a wide-angle lens. If you're using 24mm try switching up
2) sun's too bright? reflection too high for the material?
Guest nazcaLine
yes, it's deformed because of the camera lens. you probably used a wide-angle to see more.
you don't say much about your lighting settings. are you using vray sun/sky??
try to give us some more info.
Eduardo
hallo again,
i use a target light with vray shadow and 3 vray planes (vray1.46) to each of the windows
i want also to achive a good night view with a small intensity of my main light(target light) but i want very smooth vray shadow.which setting i should change?
thanx
tolis
  • 2 weeks later...
