mare96 Posted May 6, 2007 Share Posted May 6, 2007 after a long period of modelling and rendering in formz, this is my first attempt to make a descent interior view.my passion for hyperrealistic renders found vray and i think that i'm in the right way.i know that i have to enhance my efforts, but i want your very first thought about this image. i have 2 questions. 1)why the flowerpots shape is so deformed? and 2)why the pavement of the yard is washed out? tolis Link to comment Share on other sites More sharing options...
SandmanNinja Posted May 7, 2007 Share Posted May 7, 2007 mare96 said: after a long period of modelling and rendering in formz, this is my first attempt to make a descent interior view.my passion for hyperrealistic renders found vray and i think that i'm in the right way.i know that i have to enhance my efforts, but i want your very first thought about this image. i have 2 questions. 1)why the flowerpots shape is so deformed? and 2)why the pavement of the yard is washed out? tolis 1) what kind of lens do you have? I'd guess it's a distortion because of a wide-angle lens. If you're using 24mm try switching up 2) sun's too bright? reflection too high for the material? Link to comment Share on other sites More sharing options...
Guest nazcaLine Posted May 7, 2007 Share Posted May 7, 2007 yes, it's deformed because of the camera lens. you probably used a wide-angle to see more. you don't say much about your lighting settings. are you using vray sun/sky?? try to give us some more info. Eduardo Link to comment Share on other sites More sharing options...
mare96 Posted May 15, 2007 Author Share Posted May 15, 2007 hallo again, i use a target light with vray shadow and 3 vray planes (vray1.46) to each of the windows i want also to achive a good night view with a small intensity of my main light(target light) but i want very smooth vray shadow.which setting i should change? thanx tolis Link to comment Share on other sites More sharing options...
3dSol Posted May 28, 2007 Share Posted May 28, 2007 hi looking great! maybe the pool is a little too saturated also good luck 3dS Link to comment Share on other sites More sharing options...
