AFK_Matrix Posted May 9, 2007 Share Posted May 9, 2007 I am trying to render my model at a output size of 4000x3000. Now when I send it to my render machine via backburner/Net render it works fine. But if I turn off net render and try and render on my machine it comes up with a Bitmap Error?? It will render fine on my machine at an output size of 2000x1500 though :confused: Link to comment Share on other sites More sharing options...
JamesTaylor Posted May 9, 2007 Share Posted May 9, 2007 sounds like your running low on available memeory when trying to render locally. The maximum render output size links to the available RAM somehow, Aslong as you can render it thro backburner at the needed resolution you shouldn't have a problem? Link to comment Share on other sites More sharing options...
Virgil Johnson Posted May 9, 2007 Share Posted May 9, 2007 memory issue probably If I am working in Max for a while and I want to render at higher resolutions than the tests I am using, I close out Max and come back. Then I can get what I want. Virgil Link to comment Share on other sites More sharing options...
