DXF files
In Max under File there should be something called File Link Manager. This can bring in DWG or DXF files and you can then either keep the link (ie if u change the dxf then the max file will change) or you can bind it (the link with the dxf is broken and if the dxf is changed the max file won't change).
Hope that helps.
