DelfoZ Posted February 25, 2004 Share Posted February 25, 2004 This is a CLinic . The lobby. Im working with the lobby, Next is the Nurse station and the exterior Views.. Here r some steps of this works. C&C r welcome Opss. the First(1) imagen isn't mine.. Link to comment Share on other sites More sharing options...
kid Posted February 26, 2004 Share Posted February 26, 2004 Quote I like that one. Link to comment Share on other sites More sharing options...
salf Posted February 26, 2004 Share Posted February 26, 2004 Sorry, spanish version first. Hey delfoz, excelente trabajo, en especial porque nos das la oportunidad de ver el desarrollo del trabajo, pero una sola cosa, las divisiones de la ventana corrida en la parte superior derecha donde reposan las vigas, no parece estar acorde con el primer dibujo, en el cual se ve que entre viga y viga hay una division de ventana. Nice work delfoz, specially the fact that youre showing us the development of the image, only 1 thing, the subdisions on the large window frame on top, where the ceiling beams rests, arent the way it suppose to be on the first drawing, it should be 1 division between each beam. PS: your website address isnt working. Link to comment Share on other sites More sharing options...
DelfoZ Posted February 26, 2004 Author Share Posted February 26, 2004 You r Right, The architects always change the proyects after look the perspectives. u can see the imagen #5, no windows. The constructor say to me " remove the windows " and i remove the windows , then the architect say " Put again the wondows"... P.D. Spanish:Gracias por los comentarios. Y si mi pagina no esta trabajando, el link esta mal. por lo pornto tengo una version vieja de mi pagina en : NEW HomePage isn't working, Old Page is Working Here Link to comment Share on other sites More sharing options...
Chad Warner Posted February 26, 2004 Share Posted February 26, 2004 Nice process images. How are you doing the linework images? Also, are the last couple of images post-processed in Photoshop, or are they different rendering versions? -Chad Link to comment Share on other sites More sharing options...
DelfoZ Posted February 26, 2004 Author Share Posted February 26, 2004 the line work images r with Finaltoon from finalrender... all the lights are standard lights from max.. The last 2 are the same version and Edited with Photoshop. one dont have Top windows, no plants. diferent stones, etc. the last have more detail. but isnt finished yet, i need wait to the Monday for more corrections from the architect. Link to comment Share on other sites More sharing options...
CHE Posted February 26, 2004 Share Posted February 26, 2004 Delfoz, I see that you have developed your own style, I like it, you are getting there man. What render engine did you use? How much work is post-production? I have never liked RPC content, the people don't blend right in your image, maybe you should run some of the same post-production work that you did for the image on them. Great work, my two cents. Link to comment Share on other sites More sharing options...
DelfoZ Posted February 26, 2004 Author Share Posted February 26, 2004 CHE: gracias por los comentarios. Engine: "FakeRadiosity" with 65 omnis and 1 Target Direct this are the original imagen of the last WIP.. Link to comment Share on other sites More sharing options...
CHE Posted February 26, 2004 Share Posted February 26, 2004 Oh yeah, I think that the depth of field effect is too strong. You can notice that in the wall on the right. Link to comment Share on other sites More sharing options...
mauarduz Posted February 27, 2004 Share Posted February 27, 2004 i see al lthe textures too saturated and they attract all the attention from the space Link to comment Share on other sites More sharing options...
Tiny Piney Posted February 27, 2004 Share Posted February 27, 2004 My eye gets drawn to the stonewall. I might try to displacement mapping the wall or pulling the direct light off the wall. The shadow is a straight on the wall but it will not cast that way. Link to comment Share on other sites More sharing options...
ishpalsingh Posted February 28, 2004 Share Posted February 28, 2004 delfoz i like ur image ,it would b better if u show us the lighting setup,also the light settings like smoke does in his images Link to comment Share on other sites More sharing options...
