Gander0 Posted February 23, 2004 Share Posted February 23, 2004 Here is a first attempt at Photon mapping with photometric lights in Vray. Any help is appreciated http://www.cgarchitect.com/forum/filepush.asp?file=cg_all_in_events.jpg Link to comment Share on other sites More sharing options...
graphix Posted February 23, 2004 Share Posted February 23, 2004 Looks very good! However 2 comments. 1. It looks like the chairs and the table are floating above the carpet. 2. The light coming in from the window seems very muted...it may just be an overcast day outside. graphix Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted February 23, 2004 Share Posted February 23, 2004 nice image. imo some of the blacks could be darker. i can't find a true black, except maybe the window sill. to get rid of the floating feel, grab the table and chairs and drop them slightly below the surface of the carpet. 1/8" should work. this will cause the radiosity solution to create a true line. sometimes when surfaces touch, but do not cross, a true line is not created, and the shadow does not calculate right. [ February 23, 2004, 07:45 PM: Message edited by: crazy homeless guy ] Link to comment Share on other sites More sharing options...
Gander0 Posted February 25, 2004 Author Share Posted February 25, 2004 Cheers Guys Been trying to sort things out a bit though am finding it hard to get rid of the floating, got rid of the Photometric lights and buried the chairs in the floor, though it still seems a problem. Also how do i make the black darker, shadow density? Many Thanks Jan Link to comment Share on other sites More sharing options...
Gander0 Posted February 25, 2004 Author Share Posted February 25, 2004 Sorry...I always do this! http://www.cgarchitect.com/forum/filepush.asp?file=conf04Irr.jpg Link to comment Share on other sites More sharing options...
nangkri Posted February 25, 2004 Share Posted February 25, 2004 nice image Bro, but try to change the subdiv.in 3 or more, to get smooth result. best regards nangkri Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted February 25, 2004 Share Posted February 25, 2004 actually, i just learned something new today.... shane griffith was in from discreet, and i was asking him about radiosity solutions. here is what i learned about that... burying the chairs in the floor probably will not help. if you are using max radiosity it would, but not vray. max radiosity solution is a vertex solution, meaning that polygons are created to divide the geometry, and the polygons are created in respect to surfaces that cross to create vertex's ect.. ect... vray, and mental ray use a pixel based radiosity solution. each pixel is analyzed, so whether a face crosses or not does not come into play. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted February 25, 2004 Share Posted February 25, 2004 Originally posted by Gander0: Sorry...I always do this! http://www.cgarchitect.com/forum/filepush.asp?file=conf04Irr.jpg great improvement, did you lose the photometric lights altogether? ....is the chair from herman millers web site, or did you model it? Link to comment Share on other sites More sharing options...
Tony Posted February 25, 2004 Share Posted February 25, 2004 If your using vray you should elevate the chairs off the carpet a small amount so that that radiosity can create a shadow under the legs if they are not beveled. If you are using displacement on the carpet, you have to take the height of your displacement into account as well. Tony Link to comment Share on other sites More sharing options...
Alfonso Lee Posted February 25, 2004 Share Posted February 25, 2004 Hi Guys, Speaking about VRay, here is a link for your info: http://www.integra.jp/cgi-bin/yabb/YaBB.pl?board=Gallery;action=display;num=1073777347 Regards, Alfonso Link to comment Share on other sites More sharing options...
Gander0 Posted February 26, 2004 Author Share Posted February 26, 2004 Thanks for the info crazy homeless guy, the chairs are from the Herman Miller site, though I would probably have to find some that are cheaper in real value than these ones for this particular poroject. Though free models are always nice! Lost the photometric lights, yeah. Gonna try again with them today though for the sake of practise nangkri thanks will give it a go! Tony, only a bump on the carpet at the mo, hadn't thought about the displacement, good plan! Will definately give it a try. Many thanks, will post updates! Jan Link to comment Share on other sites More sharing options...
CVC Posted March 4, 2004 Share Posted March 4, 2004 very good , can you post your rendering time with your machine , anh light settings ??? Link to comment Share on other sites More sharing options...
Gander0 Posted March 4, 2004 Author Share Posted March 4, 2004 Hi CVC, Sorry I havn't got that info anymore as i've opted for light from the window space and skipped the photon lighting. If you want settings for photon light setups I suggest you take a look at the Tutorials section at www.chaoticdimension.com they have some great info for you. Hope this helps Jan Link to comment Share on other sites More sharing options...
CVC Posted March 5, 2004 Share Posted March 5, 2004 IF i have your scene i can render it better , I think so Link to comment Share on other sites More sharing options...
Gander0 Posted March 5, 2004 Author Share Posted March 5, 2004 Haha sorry CVC misunderstood what you where getting at. Have been plugging at it again and my results and settings are below. Any help would be much appreciated as im far from happy with it. http://www.cgarchitect.com/forum/filepush.asp?file=tst03.jpg settings: http://www.cgarchitect.com/forum/filepush.asp?file=settings_conf.jpg http://www.cgarchitect.com/forum/filepush.asp?file=settings_conf01.jpg Thanks Jan Link to comment Share on other sites More sharing options...
CVC Posted March 9, 2004 Share Posted March 9, 2004 thx Gander0 and sorry for my lastpost hihi , because we can to share settings together, settings above are too enough, I think you studied a lot of Natty from Chaotic because his settings for interior scene like yours. He is very well . i will post my image in next topic , your C&C are welcome Link to comment Share on other sites More sharing options...
