ienrdna Posted May 18, 2007 Share Posted May 18, 2007 Is it possible to rendrer 360 spherical HDR out of Vray Link to comment Share on other sites More sharing options...
SandmanNinja Posted May 19, 2007 Share Posted May 19, 2007 Is it possible to rendrer 360 spherical HDR out of Vray I don't know about making a HDRI, but here are the steps to make a spherical using V-Ray: How To Make a Spherical Panoramic with V-Ray ============================================ 01) load your finished room 02) put a Free Camera in the centre of the room 03) Hit F10 to bring up the Render dialog box 04) change the resolution/render size to 2:1 ratio (2000x1000, etc) 05) select the V-Ray Camera Roll-out under the Renderer tab 06) select SPHERICAL under camera type 07) select Override and type in 360 (to get a complete room) 08) render 09) at this point, I put the rendered image onto my webspace and show it off with javascript in an html file And the steps below were gleaned from this forum - forgive me, but I have lost who posted this originally. The steps below will make a QuickTime .MOV file, where-as I just use Java to show the .JPG. So, these following steps will 'replace' my Step 09 above: SETUP STEPS ------------------------------------------------------------------------------- 1. Extract files to HD for panocube http://www.panoshow.com/panocube/PC00292.zip 2. Extract files to HD for panotools http://www.all-in-one.ee/~dersch/PanoTools.zip 3. Copy pano12.dll from panoTools folder, to \\windows\system folder 4. Drag PTStitcher.exe from panoTools\Helpers onto Panocube.exe 5. Render image from vray using spherical camera, over-ride FOV to 360, and image size 2x wide : 1x height 6. Drag rendered image file onto panocube.exe The source image must reside in the same folder with panocube.exe when you drop it onto the .exe 7. You can customize the output file by editing script.txt in the panocube folder. 8. The output file will show up when completed in your panocube folder along with an html file which loads the QTVR. (the html option can be disabled in the script.txt) ------------------------------------------------------------------------------- extra note: Panolink available for $30 to create active hyperlinks between QTVRs http://www.panoshow.com/panolink/index.htm Link to comment Share on other sites More sharing options...
FOG Lite Posted May 21, 2007 Share Posted May 21, 2007 I use another pano stitcher called Pano2QTVR that I really like. You don't have to do any of the complicated installation stuff like with panocube. It already has the hyperlinks available in the free version and the professional version is only $38. Link to comment Share on other sites More sharing options...
BrianKitts Posted May 21, 2007 Share Posted May 21, 2007 Joel's got it layed out for you up till step 8, anything beyond that relates to my post for creating a QTVR, not a High Dynamic Range Image. How To Make a Spherical Panoramic with V-Ray ============================================ 01) load your finished room 02) put a Free Camera in the centre of the room 03) Hit F10 to bring up the Render dialog box 04) change the resolution/render size to 2:1 ratio (2000x1000, etc) 05) select the V-Ray Camera Roll-out under the Renderer tab 06) select SPHERICAL under camera type 07) select Override and type in 360 (to get a complete room) 08) render If all you want to do is create your own HDR for image based lighting then complete all the steps as described then just make sure when you select your output file that you save the image as a .hdr (If you aren't trying to make a QTVR then don't let the other stuff confuse ya) Link to comment Share on other sites More sharing options...
SandmanNinja Posted May 21, 2007 Share Posted May 21, 2007 Thanks Brian - I'll add your name to my notes. Link to comment Share on other sites More sharing options...
