William Alexander Posted September 8, 2003 Share Posted September 8, 2003 I have 2 problems. The first is worms or what look like worms on my sky dome. Using radiosity, excluding the dome. The dome is lit with an omni exclusively. The sky dome is a linear gradient map uvw 1 and a radius gradient map / mask uvw 2. Basic radiosity settings, this happens with linear & logrythm set at about 400. The second is the rpc masking issue. It was rendering fine, then there it was. I also got missing uvw mapping notice with the first radiosity after re opening. Any Ideas as to why and what to aviod in the future. This scene has been tweeked and really worked over. Attempting a twilight or night time scene has been challenging, with radiosity and the multitude of settings. Thanks for any help. rgrds WDA Link to comment Share on other sites More sharing options...
Ernest Burden III Posted September 9, 2003 Share Posted September 9, 2003 Why do you need a skydome at all? Do you lan to animate this scene? Otherwise, why not just usea 'background' color and be done with it? If you need a gradient in some shots you can do it very quickly in Photoshop. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted September 9, 2003 Share Posted September 9, 2003 when i use a dome, i set all lights to not effect the dome, and then use self illumination to light it. Link to comment Share on other sites More sharing options...
William Alexander Posted September 9, 2003 Author Share Posted September 9, 2003 Ernest, I'm using the sky dome attempting to capture the moonlight reflection in the windows. But with your suggestion I could use the moon in the sky dome and gradient background. Crazy Homeless Guy, Great simple soulution. Thank you Gentleman WDA Link to comment Share on other sites More sharing options...
