hrvojezg00 Posted May 22, 2007 Share Posted May 22, 2007 what setup do you use for night shots?I tried with a dark blue target light, light blue enviroment but it doesn`t look too good. Link to comment Share on other sites More sharing options...
diegofer_9 Posted May 22, 2007 Share Posted May 22, 2007 If you are using vray, a blue color in the environment should give you the main lighting from the moon. Then, all your lights inside the building can be colored slightly yellow to simulate the effect you get when photographing fluorescent lights at night. I dont think you should use a direct light pointing at the building since you really dont get light that is so direct at night. Just my take. Link to comment Share on other sites More sharing options...
blade911 Posted May 25, 2007 Share Posted May 25, 2007 u could use a night hdri in the environment slot. Link to comment Share on other sites More sharing options...
hrvojezg00 Posted May 25, 2007 Author Share Posted May 25, 2007 it`s working, thnx.one more question.I have tree images in .tga and when I want to put them on my picture in PS I get it`s background colour as well.how do I fix that? Link to comment Share on other sites More sharing options...
Tommy L Posted May 25, 2007 Share Posted May 25, 2007 You need to load the alpha channel selection in the tga then cut/paste the tree Link to comment Share on other sites More sharing options...
