archkre Posted May 25, 2007 Share Posted May 25, 2007 How do I get rid of blueish tint in withe walls from HDRI used in environment slot of Vray? HDRI intensity is OK for glass but wrong for white walls! Link to comment Share on other sites More sharing options...
Tommy L Posted May 25, 2007 Share Posted May 25, 2007 You could render in passes for greater control in post. However, I would recommend in this case that you just use the HDR as a reflection map and just tint the renders' secondary light in the environment colour slot. Then the blue will be subtle and you can tint your sun a little yellow and have control over how crisp the direct shadows are. For such a blue sky, It seems confusing as to where the sun is coming from. Do you have a direct light source, or just HDRI? Link to comment Share on other sites More sharing options...
Koper Posted May 25, 2007 Share Posted May 25, 2007 you using the vcam? you can also do it in a post editor Link to comment Share on other sites More sharing options...
archkre Posted May 25, 2007 Author Share Posted May 25, 2007 I used the HDR as a reflection map in override /environmet/reflex. varying from 0.5 to 4.0 intensity, but I couldn't notice any positive change in results except looonger times. Used maxcamera and direct light w/vray shadows. Link to comment Share on other sites More sharing options...
Tommy L Posted May 25, 2007 Share Posted May 25, 2007 I meant you should take the HDR out of the GI. JUST use it as a reflection map. Tint the environment a little blue. Use a direct light for sun. Link to comment Share on other sites More sharing options...
