gus_webb Posted April 15, 2003 Share Posted April 15, 2003 Hello- There may be an obvious answer to this, but I haven't found it yet... Does anyone know how to add more than 24 materials to a scene in Viz 4? Seems like that should be enough, I know, but unfortunately it's not. Is there a way to expand the number of material slots in the Material Editor? Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
Craig Ramsay Posted April 15, 2003 Share Posted April 15, 2003 If you go through Ted Boardmans material libary tutorial im sure he covers this You can find it in the resources section of this site Craig Link to comment Share on other sites More sharing options...
Eric Posted April 15, 2003 Share Posted April 15, 2003 Select a slot with a material you havnen't had to edit in a while, and click the "X" button. It resets the slot to the original grey ball. If you want to confirm that the material previously in the slot was not deleted, simply select the object the material was applied to, and the "Get Material from Selected" to reaquire the material. for further edits. Link to comment Share on other sites More sharing options...
gus_webb Posted April 15, 2003 Author Share Posted April 15, 2003 excellent; thank you both. seems a bit squirrely to make it work, but at least now i know how. thanks again! Link to comment Share on other sites More sharing options...
