Sketchrender Posted May 29, 2007 Share Posted May 29, 2007 I have a problem. I have modeled in Max 9, with power booleans. It will not come into Viz 2007. What is the best way to for this work flow? Thank you . phil Link to comment Share on other sites More sharing options...
Chad Warner Posted May 29, 2007 Share Posted May 29, 2007 You'll have to collapse the stacks to editable meshes or polys, and export to a 3D format (3DS or DXF or similar) Max 9 is an upgrade version from Viz 2007, so the file types are not compatible. Link to comment Share on other sites More sharing options...
Sketchrender Posted May 29, 2007 Author Share Posted May 29, 2007 thank you . That seems like the right answer. phil Link to comment Share on other sites More sharing options...
