Limbus Posted May 30, 2007 Share Posted May 30, 2007 Denis does it again: http://perso.orange.fr/dpont/plugins/nodes/Shadows.html#IESMap Florian Link to comment Share on other sites More sharing options...
warprat Posted June 1, 2007 Share Posted June 1, 2007 So how do I use it? does it work with fprime? Link to comment Share on other sites More sharing options...
Limbus Posted June 1, 2007 Author Share Posted June 1, 2007 So how do I use it? does it work with fprime? You parent a small sphere to a pointlight and set it to "unseen by camera". Then you map the IES file onto the sphere. So it kinda works like a gobo. It should work with fprime. Florian Link to comment Share on other sites More sharing options...
warprat Posted June 4, 2007 Share Posted June 4, 2007 and I map The IES map through the node editor right? Link to comment Share on other sites More sharing options...
IC Posted June 4, 2007 Share Posted June 4, 2007 Yes you add the IES map node, pick an IES file of your choice (some are included with the plug in) and plug that in to the transparency, and optionally the luminosity, channels for the sphere's material. Link to comment Share on other sites More sharing options...
warprat Posted June 4, 2007 Share Posted June 4, 2007 I m just getting a round light. have got a sphere with a point light in the centre. Poped the Ies in the luminosity and tried transarency. fprime with radiosity on. just a white spot comes out. ??? help....... Link to comment Share on other sites More sharing options...
IC Posted June 4, 2007 Share Posted June 4, 2007 Have a look over this thread..... http://www.newtek.com/forums/showthread.php?p=551689#post551689 Link to comment Share on other sites More sharing options...
solegna Posted July 8, 2007 Share Posted July 8, 2007 does this plugin only work with lightwave 9x? is there any way to use IES files with lightwave 8.5? Link to comment Share on other sites More sharing options...
Limbus Posted July 8, 2007 Author Share Posted July 8, 2007 does this plugin only work with lightwave 9x? is there any way to use IES files with lightwave 8.5? This Plugin uses the node texturin system so you need 9.x for it. I dont know of any way to use them in 8.5. Florian Link to comment Share on other sites More sharing options...
