PAR 64 stage light - model share
batteryoperatedlettuce
Hey Kev, very very good modeling! thanx for sharing
when i saw this I just had to create a gel to go with it
So i am attaching it to the post, just 'merge' it into the file( it will fit in place), it contains only the gel and a 'fake IES' light (photometric) and the gel material
unfortunately you cant realy see it in the render, just turn off the main light.
cool man
heh - cheers mate! But you've caused me more trouble now :D I'm going to have to build the spring clasp at the top (which I accidentally on purpose forgot to model) so that your gel model doesn't fall out.
Oh and I found that these lights work very well if you put a spherical vray light in them with a low setting - between 3-10, size 10-20mm and check 'no decay'
I got some quite realistic spotlight effects like this.
