Ernest Burden III Posted May 30, 2007 Share Posted May 30, 2007 I used to know how to do this, but I've forgotten. A CAD expert at one of my client's had clued me in years ago...but I haven't used the skills so they're lost. There's an AutoCad entity called LWPOLYLINE that almost nothing else will read from a DWG file. FormZ will, but it crashes on my about 60% of the time I try to import DWG files. I've reverted the version to either v2000 or even r14. Doing an 'explode' in ACAD does not make LWPOLYLINEs into regular PLINEs. But there is a way to select all LWPOLYLINEs and then change a value to make them regular PLINEs. But what is it? The only version of AutoCad I have is ACADLT-97, so it will only open up to r14. But even saving back to r12 doesn't fix the LWPOLYLINEs. Can someone refresh my memory please? Link to comment Share on other sites More sharing options...
alikashan Posted May 30, 2007 Share Posted May 30, 2007 http://discussion.autodesk.com/thread.jspa?threadID=483434 may b this is what you were looking for. i never heard/used this thing although. (lwpolyline (1 replies) Posted by: samin Date: Jul/06/06 - 15:44 (GMT) Reply hi. I can't convert lwpolyline to polyline ? please help me. best regard Reply From: Loi Truong Date: Jul/10/06 - 12:36 (GMT) Reply Re: lwpolyline Command: CONVERTPOLY Enter polyline conversion option [Heavy/Light] : -Lou wrote in message news:5228787@discussion.autodesk.com... hi. I can't convert lwpolyline to polyline ? please help me. ) and its the text of that link if link dont works for some reasons best regard Link to comment Share on other sites More sharing options...
Ernest Burden III Posted May 30, 2007 Author Share Posted May 30, 2007 Thank you. I think that helps. But what I was remembering was a variable. I looked at that angle and found the PLINETYPE variable which defaults to , but if set to forces the light PLINES to be treated differently. I think those things together may solve this. Its also hard to figure out when drawings are in paperspace and import in anything else in plain modelspace. Link to comment Share on other sites More sharing options...
neko Posted May 30, 2007 Share Posted May 30, 2007 ernest lwpolylines are polylines. i can't remember the history behind this decision, but i think around R14 they added features or functions to polylines and renamed the entity type to LWPOLYLINE (i think it means lineweight) it sounds like maybe the problem is with your older, or lighter, version. if you want something converted, send me the file and let me know what format you desire..... cheers paul p.s. i did try the other solution suggested (CONVERTPOLY) and it worked. Link to comment Share on other sites More sharing options...
Ernest Burden III Posted May 30, 2007 Author Share Posted May 30, 2007 if you want something converted, send me the file and let me know what format you desire..... Thank you so much for the kind offer. Its not a single problem, its on-going. But for a few years, none of my clients were using the LW lines in their files, so I haven't had to deal with it. But now a client IS, and I'm just having to remember what I did to get around the nasty things. As I mentioned, most programs that open DWGs simply don't read the LWPLINES. You get everything except those. But I think I've got enough tools now to deal with it again. Thanks! Link to comment Share on other sites More sharing options...
Wendelld Posted May 31, 2007 Share Posted May 31, 2007 Try the CONVERTPOLY command. It will convert a LWPolyline to Heavy Polyline and vise versa. Link to comment Share on other sites More sharing options...
