Vraysun/PhysicalCamera & Background image
drvox
Hi
Anyone had any problems applying the background image when using vraysun & physical camera?
Only way I found out since background became always black, was apllying an output to the background bitmap... didnt work at all...well at least it isnt completly black anymore!:cool:
Any suggestions? Can remenber anything else to make the bitmap compatible with the physical camera correction...
Thanks a lot!
Hi
That worked perfectly, but I'm still having a problem... In an interior view, the background becomes completly black unless I hide the glass...:(
To keep having the sky lightning effect, I've put the background image in the place of the vray sky, and also pasted the vray sun to the evirnoment slot in the vray settings.. is that the correct procedure? I wanted to keep the same lightning (vraysun+ vraysky) but with the background image..
Thanks a lot for the help ;)
