antonio_frias Posted May 31, 2007 Share Posted May 31, 2007 I have a max file of a box. When i select the box, max tells me that it is an editable poly but I don't have access to any of the sub objects. When I render it, max renders out a bush. In my material editor, if I extract the material from the box, I get a simple texture with no maps except the diffuse. I'm completely lost, I can't seem so understand what's going on or how it was created. I don't want to ask the person who sent it to me because I'm the one who's supposed to know how to work with max. Can anyone help me out on this? Thx Link to comment Share on other sites More sharing options...
chiquito Posted May 31, 2007 Share Posted May 31, 2007 mmmm sounds tricky. I would apply a diferent material slot and see what happens try collapsing it and see what happens, see if the sub seelection gets active apply an edit poly (again) see if the sub seelection gets active could it be a proxy element? or a geometry from a plug in or texture pack? Link to comment Share on other sites More sharing options...
antonio_frias Posted May 31, 2007 Author Share Posted May 31, 2007 Proxy? I didn't think of that! But... If it was a proxy object I would need to have an external file to be able to render it and all I have is the one max file. Link to comment Share on other sites More sharing options...
intero_ua Posted May 31, 2007 Share Posted May 31, 2007 Can you show a screenshot? First thing that comes in mind, is the "display as box" checkbox checked in object properties? Link to comment Share on other sites More sharing options...
antonio_frias Posted May 31, 2007 Author Share Posted May 31, 2007 Thx Alexander Your absolutely right! The "display as box" checkbox was checked in object properties. I could have spent all night trying to figure it out and I wouldn't have thought of that. My problem was that I was looking for something complicated when the the solution was actually very simple! Once again thx Link to comment Share on other sites More sharing options...
jvlive Posted June 1, 2007 Share Posted June 1, 2007 This is interesting. But there's still unanswered questions. Like where did the bitmap/texture come from if you only got a max file? And why arent the sub-objects accessible? Link to comment Share on other sites More sharing options...
chiquito Posted June 1, 2007 Share Posted June 1, 2007 exactlly. quite interesting.... Link to comment Share on other sites More sharing options...
