DAz Posted November 10, 2003 Share Posted November 10, 2003 Please help as I am very frustrated and have very little hair left. When I calculate the radiosity it appears correctly in the viewport. The 'use advanced lighting' button is checked in the render dialogue window but still the final render is totally flat, the soft shadows that I see in the viewport are not in the render. When i uncheck the 'use advanced lighting' button' the image appears practically the same. The crazy thing is that this doesn’t always happen. When i get this problem I merge the file into one that works and this works some of the time. Has anyone encountered a similar problem or am I cursed? Any help is greatly appreciated. Link to comment Share on other sites More sharing options...
MegaPixel Posted November 10, 2003 Share Posted November 10, 2003 Daz, Before we go any further, what is your exposure control set to? You should make sure you are using something other then "none" like Logorythmic Exposure. If you can't see anything in the Exp. Ctrl. preview window, then you need to tweak the brightness settings and what not until you do see something. Don't even bother rendering until you can see something in your preview window. Once we've determined this isn't the problem, we'll go from there. Link to comment Share on other sites More sharing options...
Bhanu Posted November 11, 2003 Share Posted November 11, 2003 David We are using Viz 4.0 for our Architectural renderings. Where do we get exposure.contl. preview window. Link to comment Share on other sites More sharing options...
DAz Posted November 11, 2003 Author Share Posted November 11, 2003 I have the exposure set to automatic and I can see the radiosiy effect in the preview windw. Would mixing photometric lights with standard lights be the problem? Cheers Link to comment Share on other sites More sharing options...
