Angle Snap Settings Problem
thickly
It seems that the angle snap settings don't take decimal degrees -- I am trying to set an angle for a survey project at 16.5, 106.5, etc... but the snap settings keep rounding it up to 17. I am trying to draw square rooms and that +/- 0.5 is making a huge difference, especially for the larger rooms. is there any way to compensate for this?
Thanks in advance for any help
are you sure that your drawing units are not rounded to the nearest degree ?
type in 'UN' for units and on the right hand side, make sure you have at least one decimal point for angular measurement
thanks to you both, I think Prodham nailed it -- I have to check when I get on my home machine but something tells me that will do the trick, I know here on my office machine the angle units were set to whole numbers (zero decimals).
thanks
