Sergio Posted June 1, 2007 Share Posted June 1, 2007 Hi all, has anibody has idea how can I model pillar, like in this image. Base is elipse, which forks similar like tree. Regards Srdjan Link to comment Share on other sites More sharing options...
batteryoperatedlettuce Posted June 1, 2007 Share Posted June 1, 2007 There are those who would advise nurbs for this sort of thing, but like most people with limited patience, I prefer to box model it. The method I described could also be quite accurate if you are tracing a drawing or working to a CAD file. Link to comment Share on other sites More sharing options...
Sergio Posted June 1, 2007 Author Share Posted June 1, 2007 Hello batteryoperatedlettuce, thanks for the reply and thanks for your big effort by drawing for me It does make a sence, but I am worryed is it going to be possible doing very precisely, I have to follow some cad drawing, and specially if has to be changed. I was thinking and trying using some splines, lofts, surfaceing, but did not get what I want... Aldough, I like what you did in the skech! Regards Srdjan Link to comment Share on other sites More sharing options...
batteryoperatedlettuce Posted June 1, 2007 Share Posted June 1, 2007 sure it is. Just one extra step. after roughly extruding the polys out of the base, just align the verticies up with your cad plan in an elevation view. If you want that lower branch to curve down like that you might have to bevel it out a few times, or trace a path for it and use "extrude along spline" honestly speaking, this should be so quick to make, it shouldn't matter if the plan gets changed. Link to comment Share on other sites More sharing options...
Sergio Posted June 1, 2007 Author Share Posted June 1, 2007 Hello batteryoperatedlettuce, those are nice ideas, thanks a looooooot! Regards Srdjan Link to comment Share on other sites More sharing options...
