Erikur200 Posted June 1, 2007 Share Posted June 1, 2007 Having a problem with black areas in my rendering. Have tried to search the forum with no result. When using a vray material on my window i get this black area on an isolated part of the window. Look at the pricture. When using a normal material, everything is ok. How to solve this? Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted June 1, 2007 Share Posted June 1, 2007 either you have coplanar faces, or your global reflection tick box it turned off. i am guessing it si the coplanar faces. even if you don't think you have them, double check. sometimes they sneak up on you. Link to comment Share on other sites More sharing options...
Erikur200 Posted June 2, 2007 Author Share Posted June 2, 2007 Thanks for your help , I think you was right, because I replaced the window with a new one, then everything was okay. Strange though Erik Link to comment Share on other sites More sharing options...
