drvox Posted June 3, 2007 Share Posted June 3, 2007 Here is my last render of the dinner room of the house I'm working on.. Any C&C? I really wanted to make it looks better... I'm using vraysun & vraysky for lightning. Render, QMC, Irr map, Light Cache and Exponential mapping.. I think that with vraysun I face a problem, to have enought light inside the house I need to burn the outside areas...any idea how to lead with it? Thanks a lot! King Regards Link to comment Share on other sites More sharing options...
innerdream Posted June 5, 2007 Share Posted June 5, 2007 You could try a few well placed low intensity area lights in the house and turn down the sun. I like it so far. Link to comment Share on other sites More sharing options...
mskin Posted June 5, 2007 Share Posted June 5, 2007 nice render. but it needs life. think of things besides the architecture... plantings, plate ware etc.... Link to comment Share on other sites More sharing options...
alfienoakes Posted June 5, 2007 Share Posted June 5, 2007 I think that with vraysun I face a problem, to have enough light inside the house I need to burn the outside areas...any idea how to lead with it? You could try a couple of vray planes at the windows.. It does look a bit too dark in there considering the amount of window walls there are.. Try some vray planes with a low intensity at first, and see how they look. Ramp them up gradually. It will increase your render times, but may get the result you want. Link to comment Share on other sites More sharing options...
STRAT Posted June 5, 2007 Share Posted June 5, 2007 looks more like a board room than a living room Link to comment Share on other sites More sharing options...
drvox Posted June 6, 2007 Author Share Posted June 6, 2007 Hi all, Actually, I want to put some furniture and those stuff to give ambient, but right now I'm working on the basic scene to avoid an excessive use of ram... Here are a few renders I've made recently.. The vraylight plans, I used to put them before using vraysun..right know I wanted do create a lightning system only playing with Generate GI in objects vray properties and the dark/bright multiplier in the colour mapping settings. The living room image is a bit dark, but I can't increase the dark multiplier otherwise it starts becoming wreid.. Comments are welcome Link to comment Share on other sites More sharing options...
innerdream Posted June 6, 2007 Share Posted June 6, 2007 I think you should put in the lights that will really be in the rooms and light them. The dinning room is looking better. Link to comment Share on other sites More sharing options...
