chadsmith Posted March 27, 2003 Share Posted March 27, 2003 I have been having the problem of randomly loosing the linkage between the windows and walls; ei. the wall no longer creates a hole for the window. When I try to re-link the window to the wall, it absolutely will not respond with an interactive hole. I even try to instance a working window on over,but it still doesn't work, almost like the wall has given up on any more windows for the day. Sometimes I have had to resort to changing it to a mesh and booleaning it. Can anyone tell me whets going on? Link to comment Share on other sites More sharing options...
arkitect Posted March 27, 2003 Share Posted March 27, 2003 This has happened to me before... but not randomly. I think it happens when you edit the wall in some sort of way after linking the window, i.e. adding a mesh edit modifier and altering vertices or edges. This way you can loose linkage of the window. If this is your case, don't do it. The wall is not a very stable object, though I always use it, but only for simple wall geometry. The "random" part is weird. Maybe u can give some more info on "random"? Link to comment Share on other sites More sharing options...
chadsmith Posted March 28, 2003 Author Share Posted March 28, 2003 I will instance windows over and the new one will not create a boolean or the new boolean will occur but i will loose the boolean in another window. Im telling you its kaos! even when I try to re-link the windows that do not have booleans, they just will not respond.... I dont know what is going on!!! Link to comment Share on other sites More sharing options...
Scott Erstad Posted March 31, 2003 Share Posted March 31, 2003 I had experienced the same issues, under some different circumstances. The AEC walls & windows work ok together, but dont try to do too much, keep it very simple. My time was double what it should have been on the one project I worked with this workflow on. I asked Autodesk for some direction on this, and didn't get much of an answer. I am chalking it up to no gadget needing more RnD within the software architecture. currnelty I use the AEC stuff, but ot in conjunction wiht the walls, just boolean out the window and door holes, and be off. Good luck?!? Link to comment Share on other sites More sharing options...
