Ismael Posted September 23, 2002 Share Posted September 23, 2002 I do not seem to be able to export an LP file for Lightscape. My texture attributes are not making it to Lightscape. Geometry and lights are getting through. How to do it? Ismael Link to comment Share on other sites More sharing options...
Pierre-Felix Breton Posted September 26, 2002 Share Posted September 26, 2002 You did not included a description of the textures used or materials used but here is what I can think of: - procedural textures are not supported by LVS so you may want to render them as bitmaps first - raytrace material (and possibly others) are not supported by the LP exporter and surfaces will be assigned the "Default" material in LVS (we never updated the LP export to support new VIZ features). Hope this helps, Link to comment Share on other sites More sharing options...
Ismael Posted September 27, 2002 Author Share Posted September 27, 2002 Pierre Some experimenting and help from Alexander Bicalho provided the answer for me. There were two issues. One was was a paths problem. Lightscape was not recognizing my exported paths to textures. The export worked if I used textures from my Lightscape installation. In w2k I do not have an autoexec.bat so I can change LS paths? The second is as you explained: Raytrace Materials do not export. Not even the diffuse channel! I wish this last issue would not be such. Well, Thanks for the help. Ismael Link to comment Share on other sites More sharing options...
