Tim Nelson Posted December 17, 2003 Share Posted December 17, 2003 I have a very simple question, but not simple for me obviously. In Vix or Max....I created a multi-segment line and closed it - like a closed p-line in autocad. I want to extrude it so I get the shape that I've created in whatever thickness I need. But when I go to extrude, all I get is the edge extrusion and not the face. What am I missing? Link to comment Share on other sites More sharing options...
STRAT Posted December 17, 2003 Share Posted December 17, 2003 it.s not a proper closed polyline. sub-select all the verts and weld. (or just select the start/end verts and weld together) and when extruding make sure the surfaces on start and end are switched on. Link to comment Share on other sites More sharing options...
Tim Nelson Posted December 17, 2003 Author Share Posted December 17, 2003 thanks for the tip Strat. I had a couple of vertices that were crossing too, so that might have had something to do with it also. Link to comment Share on other sites More sharing options...
nisus Posted December 18, 2003 Share Posted December 18, 2003 for better control over errors in splines: Use the Shape Check (utilities) rgds nisus Link to comment Share on other sites More sharing options...
