louis.cho Posted June 5, 2007 Share Posted June 5, 2007 I was wondering how the FG and Photons maps work on mental ray. If I want to render a scene 800x600 and check the read/write of both maps, can i use the same maps with the same image at 1600x1200? Also, if I do an animation, must I make new pass of photons and FG each frames? and finnaly, I I save both maps and make some littles adjustments on geometry of my scene...very low changes, must I re-pass photons and FG or I can use the same maps as before? Thanks Link to comment Share on other sites More sharing options...
louis.cho Posted June 5, 2007 Author Share Posted June 5, 2007 this help a lot, thanks for the fast reply. Yes, but the good news is that you can render a low quality pass of the anim to get your FG map then use that for your fin anim. The low quality animation...where can I cut to have low quality without lower FG and photons settings? anti-alias? Link to comment Share on other sites More sharing options...
