Camera moving over uneven terrain
David
Hello,
Could anyone tell me how I can animate a camera path over an uneven terrain, so that the camera is always at a fixed height above ground level? (Without actually having to check every frame by eye!)
And, on the same subject, I need to distribute several hundred trees over the terrain - they are all in the correct place in plan, is there a simple automated way of dropping them down to 'sit' on ground level?
Hope someone can help!
hi There
David
i Think therefore you are in luck (i think)
Itoosoft
http://www.itoosoft.com/
has a VIZ-ible utility called Glue which can "melt" a polyline onto a warped Terrain surface
download area:
http://www.itoosoft.com/english/download.html
you could make a terrain z-dependent path from a polyline and then use That to assign to your camera for the camera's path
and also This should work to "set" your Trees in the z-axis correctly
check This out:
http://www.itoosoft.com/english/news.html
(i havent actually used This but i have heard Peoples who have used it say That it does work)
and i Think that it is Free, to boot
Thanks
(let me know how This works for you)
Randy
www.viz2000.com
Hey, thanks for pointing out that resource, it looks superb!
I've downloaded it, but haven't had a chance to use it yet (you know how this job works, the entire brief changes overnight and suddenly I have something completely different to deal with!)
As soon as I get a chance I'll try this out and let you know what I think
