Quicktime panorama exporter question
Ged Trias
I've made a spherical panorama jpeg in Viz and now I want to turn it into a quicktime vr .mov file. I can load it into the Panorama Exporter Viewer just fine, and I can even navigate in it. But, when I want to export to QuicktimeVR the option is greyed out.
What is the deal?
Thanks
Ged Trias
I've just downloaded 6.0 and it isn't giving me the option for a full install. Only custom, minimum and recommended. I tried the custom and selected all, but that still didn't work. Are you sure it isn't Quicktime pro that is needed?
Thanks again for your help.
  • 1 month later...
I'm having this same problem with Max 6. I've installed Quicktime 6.3 with custom and then selecting all the possible options to install. But in Max the export to QTVR option is greyed out.
Did anyone ever find a solution to this? What am I missing?
Thanks
Colin
Do you have Administrator Powers in the system? Was MAX installed as the same user as QuickTime? Can you view QTVRs in Quicktime?
I don't know what could be causing this problem - seems to me that MAX is not locating a specific Quicktime DLL needed for this to work.
Try using the version of Quicktime that ships in the MAX CD. Even though I have used QT 6.5 in my new system and it worked fine. But I always install everything as an Administrator which could be the difference.
Alexander
