MannyG Posted June 7, 2007 Share Posted June 7, 2007 This is my first post so sorry if its a newbish question but ive been looking for a tutorial on creating a skydome..any help or ideas?..much thanks Link to comment Share on other sites More sharing options...
Horhe Posted June 7, 2007 Share Posted June 7, 2007 In what 3d package? What lighting plugin? Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted June 7, 2007 Share Posted June 7, 2007 Using Max, you can try it's native skydome, but I wouldn't advice actually using it in production. Assuming you dont have acess to other renderers, you can try using the ring technique. It's very easy and effective, and there's a tut in the forum. Type "Delfoz ring technique" in the search engine and you'll find it. It's a very old thread, but still useful. Link to comment Share on other sites More sharing options...
MannyG Posted June 7, 2007 Author Share Posted June 7, 2007 Im not really worried about the lighting, what i want is to just have a sky. I have my model and the lighting i just want a sky. I searched the ring technique but that has to do with lighting. I tried making a sphere and just reversing the normals so the sky map is on the inside but it renders black. im on max 9 if it helps Link to comment Share on other sites More sharing options...
Tommy L Posted June 7, 2007 Share Posted June 7, 2007 You need a spherical map in the environment slot. Go to the rendering dropdown, environment, then browse for a map. You then have to drag the map into the material editor and change the maps' mapping mode to spherical. Before you do this, you'll need a spherical environment map. Search on google, try evermotion.org/net (cant remember www suffix) and go from there. To be honest, you should just go through the help files. Link to comment Share on other sites More sharing options...
MannyG Posted June 7, 2007 Author Share Posted June 7, 2007 Thanks that did the trick for now...i messed with it to get things how i wanted them its just for a simple project im doing nothing huge just to show enviorment. Link to comment Share on other sites More sharing options...
