illyrianeye Posted August 17, 2003 Share Posted August 17, 2003 Im doing my first exterior lighting with radiosity rendering. im using the daylight system for nyc location. i cant get the ceiling and wall texture to be smooth, any suggestions? Link to comment Share on other sites More sharing options...
Alex Ryan Rubio Posted August 17, 2003 Share Posted August 17, 2003 apply a radiosity/advanced lighting material over your material. keep submap. from there, lower your bump scale to something less than 1,0. (0.2 or 0.1 perhaps? Link to comment Share on other sites More sharing options...
proces2 Posted August 17, 2003 Share Posted August 17, 2003 it looks like you might have regathering turned ON. if so, reduce the samples value (default 64 is way too high) and increase the filter radius value. that should help get rid of some of the splotchiness. also, note that the values for regathering will be influenced by your rendering size. its hard to get the regatherer to work sharply with lo-res renderings (without getting the splotchiness/noise that you are getting). its built more for rendering hi-res images. Link to comment Share on other sites More sharing options...
Fran Posted August 17, 2003 Share Posted August 17, 2003 Originally posted by illyrianeye: Im doing my first exterior lighting with radiosity rendering. im using the daylight system for nyc location. i cant get the ceiling and wall texture to be smooth, any suggestions? Hi, can you post your radiosity settings? Are you using a bump map on the troublesome surfaces? If so, try unchecking that map slot and seeing what it renders like. Link to comment Share on other sites More sharing options...
illyrianeye Posted August 19, 2003 Author Share Posted August 19, 2003 Guys thanks for all of your replies, but im having trouble re opening that file, which i saved with radiosity. im in the process of re texturing it and i will post an updated rendering with the radiosity info as well. thanks again and sorry for the delay Link to comment Share on other sites More sharing options...
